DrewE
Mar 17, 2017Explorer III
When both valves are open, does the black tank drain or only the gray water tank? If it's only gray water, everything points to a clog in the black tank drain system--a fairly straightforward problem conceptually, but definitely not a lot of fun to fix.
If both tanks empty, you have something plumbed very strangely indeed or have a very peculiar problem with the tank vent system.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
