HappyKayakers
Mar 18, 2014Explorer III
If memory serves correctly, that cable will detach from the valve body fairly easily, probably 2 bolts on the valve body. Disconnect the cable, then use needle nose pliers to push/pull the valve blade. If the valve operates freely, then the problem is on the cable end.
You can try lubing the cable, maybe not torque the bolts so tight when reattaching.
