mobeewan
Feb 02, 2019Explorer
As long as you have enough liquid and chemicals in the tank you should be okay. I've gone as long as a month after a trip without dumping the tanks. Everything was fine. I even forgot to dump a portable potty after a tent camping trip for 6 months. It rinsed out fine.
I've gone 30 days or more without dumping my 40 gallon tank while living in my TT and me being the only occupant. I'd usually dump once a month and give it a good rinse about every other time. No crust in the bottom of the tank. I used plenty of black tank chemical buying the 32 oz size adding a little once a week. I use Angle Soft TP in the trailer and at home.
Never had a problem with the dreaded poo piramyd. I did have to use a stick on occasion to push the floating TP from the last flush that had not quite dissolved and settled away from hole as the tank was getting full allowing a couple more days use until I had time to dump and rinse the tank.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
