In one of my overhead lights I have installed a small led bulb. It has 4 rows of 3 leds mounted on a small circuit board. One row of lights have started blinking all others are ok. Any way I can fi...
Most likely a bad solder joint. If you have a soldering iron heat up all the solder joint you can find and see if that works. I have fixed several that way. Way complicated for most but I replaced the IC on one with success. Got a lot of ten from China for much less than a dollar ($0.29 with free shipping!)
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
