js6343js6343's avatar
js6343js6343
Blown fuse help
I pulled my TT from storage the other day and hooked up a freshly charged battery. First the positive terminal then negative. I noticed quite a spark when I connected the negative terminal, but thought that should not be a that unusual. But I double checked the polarity as OK just to be sure.
I entered the TT and found that all my 12V endpoints do not work. Went to the fuse panel and found both main 40 amp fuses blown.
Anyone have any ideas what would cause both main fuses to blow. I will go ahead and replace them today, but am concerned I might have an underlying problem. Though I am not sure what that would be.
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 12, 2025
