Fisherguy's avatar
Fisherguy
Blue Sea or Waytek
Getting ready to order parts for my solar install, rather than using a combiner box I want to use feed through connector as shown here:
Blue Sea makes them:
Blue Sea feed through
and so does Waytek:
Waytek Feed through
The Waytek are quite a bit cheaper, I need to order some bus bars, breakers etc, are the Waytek parts as good as the Blue Sea?
  • RJsfishin wrote:
    Its plastic ain't it ?
    A feed thru connector would be a ss stud (or cut head off bolt) w/ 2 ss nuts, and flat washers. There is nothin cheaper, easier, or better.
    Blue Seas, no better than any other good quality, and rediculously priced !
    Hmm, never even thought of making my own, might be an idea... :h
  • SCVJeff wrote:
    How do you think these will standup to UV? That would make me nervous...
    It's in the fridge vent, it will be covered by the lid to the fridge vent, I didn't think UV would be an issue there, I'll check with Blue Sea, see what they say.
    I don't want to drill more holes in the roof than I need to, don't like the idea of screwing boxes to the roof and would never mount one on the side of the trailer.
    If Blue Sea says it's not a good idea I'll look at putting the pvc box inside the fridge vent.
    dons2346 wrote:
    Blue Sea is made in the USA and are for the marine market. Much better quality than the other brand listed
    THanks.
  • Its plastic ain't it ?
  • Blue Sea is made in the USA and are for the marine market. Much better quality than the other brand listed
  • RoyB's avatar
    RoyB
    Explorer II
    I too use the PVC ELECTRICAL JUNCTION boxes with weather tight lids. I like to mount these on the trailer side however to cut down on the direct SUN UVs...
    I will mount one on the outside wall aligned up with one on the inside wall and drill out a large two inch hole in the middle of the boxes. Then I can use PVC FLEX lines to route the cables where they need to go. I would always add a large short section of solid PVC tubing glued in place to seal off the large hole between the two PVC Boxes. You can pull the weather tight lids and gain access to the cabling.. Everything installed inside conduit from point A to point B. All of my best DC CABLES for Batteries Installations used this idea.
    LOWES has the whole assortment of BOXES with different number of ports for any project you may need.
    Working with NAVELEX SYSTEMS in my working years for all sorts of remote installation the BLUE SEA PRODUCTS were proven to be the best choice for high current switches-fuse assemblies-external DC sub panels-terminal blocks etc.. The ANCOR BRAND Marine cables were the cables and ring terminals of choice as well.
    Roy Ken
  • How do you think these will standup to UV? That would make me nervous...
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
