MrWizard
Jun 10, 2017Moderator
Click link..From the above
DROCK wireless meter on Amazon
Yes this meter has more functions, this is the Americanized version of meter MexI referred to in another thread
DROCK usually provide better written English instructions,
Than you get when ordering direct from China on eBay
Not as simple to use
The default settings will be way off from RV battery capacity etc..
Will have to set battery bank size in amp hours and charge bank until absolute full charge
Then set current SOC to 100 percent
In order to establish accurate readings counting up and down on amp hours
DROCK sells very good stuff
I have bought several items from them,
What I really like about the first one, is No shunt
It is a 'Hall Effect' current sensor
Only the two power wires get attached , the sensor goes over/around the line being measured, then you can check it at the meter, or use your phone remotely, well approx 31 ft aka 10 meter via Bluetooth
