BFL13 wrote:
As a sort of rv.net tech issues survey, would you like your converter to have a bluetooth module that you could set the charging parameters Vabs and Vabs timing to any voltage and time, kind of like
No. I would not for multiple reasons so let's start.
First: most folks have no clue as to how to set 'em
But mostly I'm concerned with too many BT devices (Though they make a rather ingenious use of radio spectrum (Spread Spectrum) there is only so much room.. Hedy Lamarr invented that by the way.
But more important if it's BT then a hacker can adjust it for you..And not in a way you'd approve of.
Or .. Well I keep opening a BT app on my phone. it's mostly read only and the only "Write" function is harmless but I keep opening it by accident... imagine adjusting converter....by accident.
A good front panel or a WIRED remote or a Plug in and unplug remote would be my choices.. Way safer.
