Rbertalotto
Aug 27, 2015Explorer
Interesting...I just found this information on the Bogart charge controller....
pre-absorb boost charging is not recommended by any battery manufacturers that I know of. It only works on batteries that have been moderately cycled where it can be used to take advantage of peak solar conditions at solar noon, and without excessive heating of the battery. For batteries that have been discharged to 50% SOC it will get your battery way too hot by forcing too many amps into it at the higher boost voltage for the first hour.
Finish charging (delayed boost) is different. It is an algorithm designed to limit current to the battery to no more than C/10 to prevent excessive water use and heating of the battery. And at the same time provide a high voltage finish stage that fully desulfates the negative plates. It is now almost the industry standard recommend charge profile (Trojan, US Battery, Surrette, and all industrial forklift/floor maintenance, locomotive and marine batteries). Industrial grid-powered forklift/floor maintenance and marine chargers have used it for years (IUIa with no float). Currently there are only two RE chargers that I know of that can do it - the XW from Schneider and the SC-2030 from Bogart. Of the two, only the Bogart SC-2030 does it correctly.
