Reisender
Apr 12, 2022Nomad
valhalla360 wrote:time2roll wrote:valhalla360 wrote:Easy software update if there is a calling.
Probably far fewer Tesla owners are likely to benefit on a regular basis from a similar system.
The Ford system outputs 120v AC power. I believe around 3000w peak.
To my knowledge, the Tesla can't do that with a software change. The current 7pin output being discussed is something like 7-10amps 12v DC. OK for keeping the battery up for small loads but doesn't really take advantage of the large battery bank that's available (assuming you aren't saving it for propulsion).
Doesn't mean they couldn't add an inverter at some point (physical not programing) but as mentioned, Tesla users who would significantly benefit are likely a far more rare buyer.
Yah, it’s 12 amps constant and 16 amps peak. It’s on a software fuse. Resets after 10 minutes is you exceed the rating.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
