vicmic1983's avatar
vicmic1983
Boondocker BPC4-60 Breakers
I am replacing my old Magnetek 7300 with the recommended replacement the Boondocker BPC4-60. I have sent to emails to Randy at Best Converter and no response! My 7300 had the following breakers, 1 30-15 Tandem and 2 15-20 Tandems. The Breaker diagram for the Boondocker appears to indicate that the main is a double 30 however there is no information to tell exactly what the main configuration is. Any help out there?
34' Skyline 5th wheel triple slide 50 AMP.
  • Everything goes through the main and more than likely, the converter is connected to it.
    Are you replacing the entire panel?
    Usually we just swap the converter section and keep the panel with breakers and fuses.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
