BFL13
Jun 09, 2019Explorer II
rrupert wrote:time2roll wrote:
Yes that would be a single stage converter. Low for charging and a bit high for float charge in warm weather.
So you are saying my WFCO is not three stage regardless of what the manual says?
He is saying effectively, you have a single stage.
It is a three-stage, where it will go into boost only if it "sees" under 13.2v on start-up. That is /was in the manual about the 13.2v "trigger". Can't say about the 13.2, but you need to be not using the trailer at the time or it will stay at 13.6.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
