hinkle_e's avatar
hinkle_e
Boondocking and charging with Toyota factory inverter
I am currently towing my 2014 Palomino Solaire 209BH with a 2008 Tacoma which is equipped with a factory inverter (plug in the bed) capable of putting out 400 watts. Would I be able to run a battery charger off of this to recharge my house battery while dry camping? If it is possible, would it be more efficient to run the camper charger or a stand alone?
Thanks,
Eric
  • I have been able to run a Vector 20a charger at 20a that wants 320w for input from a 400w MSW inverter (rated for 320w continuous) clamped to the truck battery. Of course you want the engine running so the truck battery does not go flat.
    Even with the hood up, you need to keep the inverter away from the engine (not a problem for the OP) because the heat triggers the inverter's heat shut-off. Hang it out down over the fender.
    This was a test for if my Honda gen didn't work (never happened yet) and not intended as a regular procedure.
  • Hi,
    Is it modified sine wave or pure sine wave? Battery chargers are inductive devices and may not produce full power on MSW.
    The smallest "converter" is about 40 amps output DC with an input of approximately 700 watts AC (if the house batteries are "hungry"), so a stand alone 20 amp charger may be the biggest you can run.
    A 400 watt inverter represents about a 40 amp load to the electrical system, so it would be best to have the engine running when ever the inverter is to be run for more than brief periods of time. Be sure to lift the hood on the truck to help keep the alternator cool.
    If the battery bank is "hungry" you may get a lot more amps going in by using jumper cables.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
