  • One afternoon one nipped my finger behind my pillow. Ran twenty feet whiskers twitching then tuned around. I chased him another 20' and he did the same thing. Unreal. The sucker wanted to play tag. Every afternoon he would show up at 2PM wanting to play Hide And Go Squeak. They are not the awful Norway Rats. Sucker played for ten minutes and then probably hid and rolled a joint. Talk about Nutso...
  • I use a fair amount of Techflex. Just used some the other day to shield a battery cable in a tractor. It isn't rodent-proof but it must be rodent-resistant as I've never seen any bite marks on it. Of course, hopped-up Mexirats may be capable of who knows what.
  • We gots rats the size of Rhode Island Red Roosters. Had one try and gnaw on a fence charger wire over the weekend. It was easy to follow the dots into the bushes. Sucker ain't gonna gave constipation for while.
    This braid would really gussy up a battery / inverter / load center compartment.
    Run a 1/2" adhesive lined ring of heat shrink around the end of the braid to stop playing Red Cross donor.
  • That stuff is used on the outside of lots of hoses at the chemical plant where I work. It might just a tad overkill if UV resistance is the only need..... :)
    But let me tell you if one of those fine little wires breaks, it sticks out and it will go in your hand like a needle!
  • Thanks much for that link.
    I bookmarked it for solving as of yet unforeseen future problems. Pricing isn't too bad, either. :)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
