Old-Biscuit
Jun 12, 2014Explorer III
What are 2 pressure relief valves?
If water pump pressure doesn't cause problems then need to set water pressure regulator to 45# static pressure(no flow). Then that would be the MAX pressure your city water line could provide.
Fix the high water pressure issue first...then fix the leak
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
