westend
Oct 21, 2013Explorer
ScottnSherrie wrote:If you want to try the service route, make sure you exercise the caliper while it is disconnected, to the full throw. Get some air and lubricant under the exterior dust seal of the caliper piston, too. IMO, you've pretty much described a sticking brake caliper.wa8yxm wrote:
There is another issue.. This one bit me on a car
The brake hose is a multi-layer thing, SOMETIMES the inner layer can fail in such a way it becomes a one-way valve. Allowing brake fluid to enter the cylinder and engage the brakes, but not allowing it to return to the master cylinder and tank thereon. OF course sitting in your drive waiting for you to get to it.. It leaks back.
Someone else posted the same thing. My plan is to service all the brakes with a good cleaning and greasing the parts that need greased (doubt they have ever been serviced) and replacing the hoses at each caliper. Once that is done it will be time for a test drive and measure the heat off all the discs every few miles. I have an IR temperature gun that makes that easy.
If they are still overheating, I'll replace the caliper.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
