dougrainer
Nov 17, 2018Nomad
Happytraveler wrote:
Our Onan Generator in our motorhome will not work when the gas tank is 1/4 full. I guess it's a safety thing.
I believe the OP states the Onan will NOT attempt to start/turn over. That means he probably has a battery/12volt voltage problem. He needs to state if he tried to start the CHASSIS engine. His Onan may start from the Chassis and it is dead from 6 months of being parked.
Fuel at 1/4 is not a safety thing. It is to keep you from draining the Gas tank when on Genset and then having NO gas to start and drive the RV. ALL correctly installed gensets in a Motorhome have the 1/4 tank pick up system. Doug
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
