MEXICOWANDERER
Oct 20, 2018Explorer
THIS
Is a battery combiner bi directional allows all batteries to charge automatically
THIS
Is a manual re-set high amp circuit breaker. This allows you to reset breaker in 10 seconds and eliminates fumbling with fuses
THIS
Is an 800 amp Ford starter solenoid which vastly prolongs the life of a battery combiner which is mounted next door. Battery combiners cannot pass high amperage without danger of frying the contact discs.
USE A FUSE when instantaneous reaction is demanded, not applicable when paralleling batteries. Burn 8 fuses trying to diagnose a fault is a loser.
THIS
THIS
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
