CptSydor's avatar
CptSydor
Breakers for solar
I purchased all the components for my solar about 1.5 months ago. At that time I ordered a few inline 30amp fuses, but unfortunately they haven't arrived yet. I have everything else, so I've been waiting to install, unfortunately I'm leaving in 2 weeks on a 3.5 month trip, so I need to get this done now.
I ordered ones like this since I was hoping to have it mostly plug and play. Just connect things together. I was hoping to stay way from splicing wired or adding terminal connectors.
In absence of those, what are my options? I can get these inline circuit breakers. Are they appropriate for the places I was going to put fuses?
I could splice in fuses like this, but they always seem to be larger gauge wiring than my solar, but maybe I haven't looked carefully enough.
Any other recommendations? I'm in Canada, so I have places like Princess Auto, etc to work with. Can't order anything online a this point. Preferably the easier the better. I'm confident I can start making new connections, but its not something I've really done.
  • Fuses where needed ? Where are they needed ? My installation didn't need any.
    But then, if you lack confidence in your installation, then maybe you need them.
  • jpmihalk wrote:
    I used the fuses like in the last picture. I then used shrink wrap to seal the splices (and covered them from the elements) and they have been working fine ever since.
    X2
    Just match the wire gauge and thin install the correct amp fuse.
  • What size fuses are you looking for? For what purpose? If you have only 1 solar panel or 1 string of solar panels in series then there is absolutely no reason to install a fuse between the panel(s) and the controller.
    If you have more than 2 panels or strings in parallel then you do need fuses on each string.
    Square D QO series breakers are rated for use in DC circuits up to 50 volts. This makes them usable for 12v and 24v solar systems but not 48v since a 48v system will be over 50v when charging. You can get QO breakers and panels at any Lowes, Home Depot, or electrical supply.
    Or, you can get purpose made DC breakers. MidNite Solar and Outback both sell them (and some others I'm sure). Most any solar equipment dealer should be able to help.
  • You really only need a fuse close to the battery.
    And that is not even necessary if the wire is in plain view and not too far from the battery.
    You don't need fuses from the panels to controller. The wire should have at least twice the ampacity of the panels and will not even get warm when shorted together.
    So cancel your order before they ship.
    Using a wire as a fuse. Great idea :S
    Very common with 12V vehicle electronics. It's called a fusible link. Just a short piece of wire of thinner gauge than the rest, so it burns out first in the case of an overload. Although I don't think that's what time2roll meant.
  • Also check your alternator output and your starter circuit. Breakaway brake system?
    The solar should not overload the wire because the ampacity should be well above the solar rating. Really just protecting the wire from power coming from the battery. Yes if the controller is right there next to the battery IMO skip the fuse is OK. Several feet away or going through blind areas or anything else tricky about it then yes put a fuse close to the battery.
    Also don't forget your battery interconnect fuses. One at each end.
  • After using all of the above and always having thermal issues I went with a pair of Trac digital circuit breakers. Select 30 - 60 Amps, manual or auto reset. More expensive but problem free. Have them set to 30 Amps before the charge controller and 40 Amps after.
    https://www.tracoutdoor.com/shop/electrical-items/12v-digital-circuit-breakers-with-display/
  • Many charge controllers require you to have circuit breakers installed for the panels and for the battery leads. Can you do without them? Sure you can, but why would you? As stated by other posters I wouldn't let it stop me from a trip if I didn't have them, but I would install them as soon as possible.
    Lots of the so called professional installers don't install them which doesn't make it right, but does prove their incompetency.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
