CptSydor's avatar
CptSydor
Breakers for solar
I purchased all the components for my solar about 1.5 months ago. At that time I ordered a few inline 30amp fuses, but unfortunately they haven't arrived yet. I have everything else, so I've been waiting to install, unfortunately I'm leaving in 2 weeks on a 3.5 month trip, so I need to get this done now.
I ordered ones like this since I was hoping to have it mostly plug and play. Just connect things together. I was hoping to stay way from splicing wired or adding terminal connectors.
In absence of those, what are my options? I can get these inline circuit breakers. Are they appropriate for the places I was going to put fuses?
I could splice in fuses like this, but they always seem to be larger gauge wiring than my solar, but maybe I haven't looked carefully enough.
Any other recommendations? I'm in Canada, so I have places like Princess Auto, etc to work with. Can't order anything online a this point. Preferably the easier the better. I'm confident I can start making new connections, but its not something I've really done.
  • WindyNation recommends fuses. I installed. No issues. Why second guess the manufacturer?
  • rjxj wrote:
    I have used this
    These are quick and easy if you want to disconnect the panel from the controller. If you want top quality, go with blue seas or bussman.
    I also have used these, in the 30Amp flavor though. Worked just fine.
  • I ordered some like that but they felt so cheap that I wouldn't use them. YMMV, I decided to order some Blue sea circuit breakers instead.
  • rjxj wrote:
    I have used this
    Those are what I have on order. Unfortunately they are MIA in shipping and it they don't seem to be available locally. I ordered them a month ago with everything else :(
    I bought some inline fuse systems today. I think I'll just splice those into the system. Doesn't seem like there are better options.
  • rjxj wrote:
    I have used this
    X2 on this
  • Just my humble opinion, for a small array like an RV will have, why bother with fuses at all between the panels and controller? They cost you voltage (voltage drop) and introduce more failure points for corrosion. How about a simple disconnect switch, when you need to work on the panels, or the charge controller?
    The first fuse picture, you shouldn't have to order - Best Buy will have that holder and the fuses for it, it's common for automotive sound installs. I'm surprised Princess doesn't.
    The middle breaker is complete junk, well, it's handy for things like lights I guess, but I would avoid it.
    The last fuse is OK, I wouldn't wrap it with anything, that will just trap water in, not keep it out. Put some dielectric grease in there if you want more corrosion protection.
  • I have used this
  • I used the fuses like in the last picture. I then used shrink wrap to seal the splices (and covered them from the elements) and they have been working fine ever since.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 12, 2025
