NinerBikes
May 05, 2014Explorer
Salti dawg has the correct approach.
Charge some low batteries with it first. After 2 hours, turn on the electric water heater. When that stops cycling, let it run 1/2 an hour doing the battery only. Then turn everything else off and run the AC for an hour. Then try to run the AC and the microwave at the same time. Or do the AC and the electric portion of the water heater at the same time, the next day. That should do it.
That should do it.
That should do it.
