JiminDenver
May 06, 2014Explorer II
Thank you for the replies.
Since the trailer is in a storage lot, I'll get a tank thru the generator here at home using a pair of 1500w heaters at different settings and then do a oil change.
Since we got the solar, exercising the old 3500/4000 was the only time it has run. I go out monthly, drop in some gas, start it and run a 1500w heater. Afterwards I drain the tank and run it dry. It has always started with a single pull until this last time when first the cord broke twice and then the starter itself went out. I gave it away thinking we'd get a 3100i...oops.
One thing while the remote start sure is nifty to have, the extra 20 pounds will make it so I can't lift it by myself. I wasn't suppose to lift the old one but I could when I needed too.
