breeno's avatar
breeno
Bridged EU2000s: how long on a tank of fuel?
Just picked up 2 Honda EU2000s to bridge together for use with the 5th wheel.
I also ordered up an external tank, but it hasn't arrived yet and we're dry camping this weekend at the race track.
For folks running this setup, how long should I expect the generators to last on the tanks? (probably running the 15k A/C during the day)
Thanks!
  • Roy, why would paralleling two generators double the run time? Each engine will run the time it can on its own tank. I hope you were kidding.
  • RoyB's avatar
    RoyB
    Explorer II
    I get 6-7 hours run time out of my single EU2000i on one tank of gas running minimal use items... I believe my fuel tank size is one gallon.
    If I had two 2KW Honda generators paralleled together I would expect this to double or 12-14 hours...
    Of course running an Air Conditioner full time would probably be a somewhat max load for the generators using more fuel...
    Roy Ken
  • During power failures at the cottage with the fridge cycling on and off I get 10+ hrs on a gallon. In the evening we have one light and the TV for a couple of hours.
  • 2oldman wrote:
    About 3 hours at 100% duty.
    wrong....I am running my 2 Honda's without any extended tanks (about a gallon in each) with my AC and getting 6 hrs... Just purchased my 5 gallon Bergs and will be trying it in Richmond in a few weeks.... I am hearing stories of 20-25 hrs ??? We will see...??
  • You may find that your generators don't load share well and one may consume more fuel than the other. There have been post here in the past and I have seen that with my Honda Eu2000s and EU 1000s.
    Dick
  • It depends. If that AirCond is going to run almost continuous then maybe 3 hours. If the AC just cycles on occasionally then 6 to 8 hours.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
