Himalayan_Hillb's avatar
May 09, 2017
Broke dinette table post socket
Hey so quick question. The little dinette table post which goes into a hole in the ground got stuck this evening. I had to pull pretty hard to get the post out and when I did it had broken away the metal socket which it inserts into in the floor. That metal cup has now fallen and is stuck inside part of the frame. Any idea for how to at least somewhat fix this? You can see a few pictures I took to help illustrate the issue at the following links:
https://drive.google.com/open?id=0BwAMKyAySE49c2xFYTVzMEZQYlU
https://drive.google.com/open?id=0BwAMKyAySE49eGtzSkpQLVlmN00
https://drive.google.com/open?id=0BwAMKyAySE49NS1VQURkTHoxLWM
  • evanrem wrote:
    Mine broke and table was wobbly until I replaced the socket. It was a simple job.
    I think the OPs issue is that the broken off base is jammed into the hole. not easy to remove.
    bumpy
  • Mine broke and table was wobbly until I replaced the socket. It was a simple job.
  • can't pull it out with a magnet or needle nosed pliers? drill a hole in it and insert L shaped wire. just jam a replacement down in hole?
    last resort, use a non-flush mount receptacle.
    bumpy
