BFL13
Aug 13, 2019Explorer II
Also some of the EPSolar controllers like my Tracer.
Some controllers have temp comp mounted with the controller, which might be inside where it is warm while the battery is outside in the cold.
I forget why to put it on the neg battery post. Was explained a while back, maybe by PT. Of course it helps when the battery has a post of the type you can put it on!
The TempAssure for the newer Parallax converters also has such a wire to the battery. Has the temp sensor just at the ring lug on the wire
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 10, 2026
