buylow12's avatar
buylow12
Broken grey water tank.
So last night I was doing the dishes and I heard and felt a huge boom. At first I thought my fifth wheel had rolled somehow or something but when I went outside I could see and smell grey water leaking out of the bottom of the protective plating. It looks like the corners of it actually are pocking out of the bottom. What can I do?
  • You are lucky it was the Grey water. I have a small leak in my Grey tank somewhere near the top. I can fill it most of the way then I get water coming out from my under belly. I can not locate the crack with a flashlight or unless I rip out the under belly. So, I circumvent the problem by just leaving my Grey tank open to drain into the sewer line.
  • Probably poor bracing and support. Every now and then someone posts on here about the tanks falling out. RV quality
