John_Joey
Aug 30, 2013Explorer
I really hate it when people suggest using a tool to cut the plug. As you found out the treads are aluminum and can be EASILY damaged. Lucky you could cut new ones without having a further problem.
Wolfe had the correct answer. Here is a thread I did showing how it's done. It is cheap and very simple with no problem of wrecking the threads. If it doesn't do the trick then resort to more destructive ways.
EASY PLUG REMOVAL WITH PICTURES
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
