Dave_H_M
Oct 11, 2017Explorer II
SCClockDr wrote:
Broken rocker arm and bent push rod indicates a mechanical reason for the damage. Removal of the head would be my first move. You need to find the cause, otherwise you are dealing with a landmine.
You need to rule out a bent valve, fouled valve guide, or broken piston (top separated from the bottom).
What the clock dock says. my bet is that there is some kind of mess in there.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
