Ron3rd
Oct 15, 2017Explorer III
SCClockDr wrote:
Broken rocker arm and bent push rod indicates a mechanical reason for the damage. Removal of the head would be my first move. You need to find the cause, otherwise you are dealing with a landmine.
You need to rule out a bent valve, fouled valve guide, or broken piston (top separated from the bottom).
X2, first thing I would want to know is why the pushrod bent in the first place. Not normal
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
