gwwing2's avatar
gwwing2
Broken valve cover E350
Just wondering if anyone has had a problem with the valve covers cracking/splitting on Fords E350. It was a first for me! Guess the new plastic covers are not as reliable as the old metal ones. This happened on my 2014 Coachmen Freelander CB19 which is on a 2013 frame. 9500 miles. Fortunately happened just prior to arriving at Hendersons Lineup in Grants Pass Oregon. Although it was warranty work the nearby Ford dealers would not work on it without a appointment, first available opening in a week. Since I couldn't wait a week and would have had to tow the rig in, we had Hendersons do the work along with the planned RPA and suspension work. Had not planned on the extra $ but looks like Ford prefers to ignore this issue with us. When the valve cover was removed, there was a 2.5 inch split on the bottom edge that stuck out 1/8 - 1/4 inch. The mechanic that removed the cover said the two bolts on either side of the split were torqued down very tight and thinks that may have caused the break.
  • I freaked when I saw plastic radiators. Now this.
    I can see it now...
    "But that crankshaft is not -ordinary- plastic. It is hemongothermointragridcryo plastic. You cannot begin to imagine the weight savings and fuel mileage advantages."
    A week's wait? What a perfect example of the durability and reliability of today's motor vehicles. How sad.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 18, 2025
