brulaz
Sep 26, 2016Explorer
mike-s wrote:brulaz wrote:Someone has been lying to you. Burning propane is burning propane. It may be efficient in terms of complete/safe combustion, but it's going to produce water (and carbon dioxide) according to the same chemistry as the others - C3H8 + 5O2 = 3CO2 + 4H2O.
The catalytic Olympia heaters are apparently more efficient with less moisture released than the others,
No liars, just a mistaken assumption on my part. You are right.
With respect to vented propane heaters, I cannot find anything as small (3-6K BTU) as the unvented Olympia Catalytic heaters. The smallest I've seen (10K) is ~10" thick and would be more difficult to fit in our trailer's small living space. But doable. They are also quite a bit more expensive.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
