jrnymn7
Nov 03, 2014Explorer
BFL said,
"-$105 buck converter with fancy readouts attached, which has way higher voltage input limit of 60v (so it can run two 12v panels in series, which the Eco-W at 42v cannot)"
What am I missing here? Two 12v panels (say 2 x 18v) would provide up to 36v, less than the E-W's 42v.
It appears to me, matching up solar panel output voltages with buck converter input voltages is not the problem... lots to choose from. The issue seems to be with finding a buck that can handle the amps output from the panel. And like with everything else, big amps cost big bucks (pun intended).
