westend
Nov 03, 2014Explorer
What's messing you up is that you're trying to fit your buck converter into the same relationship as the total function of an MPPT controller and that isn't the case. Salvo defined it above. The MPPT controller is able to control output to the battery by boosting more amps at the sake of voltage. Your buck gismo is more of a voltage source and can't vary voltage to increase amps to the battery.
