BFL13's avatar
BFL13
Explorer II
Nov 01, 2014
Buck Gizmo -Volts vs Amps ? UPDATED
Update 5 Nov. (It didn't work out as hoped)
I got my little gizmo, see close-up photos here
http://www.ebay.com/itm/DC-DC-15A-Converter-Buck-Adjustable-4-32V-12V-to-1-2-32V-3-3V-5V-24V-Step-Down/281206555382?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D25217%26meid%3D8539ba1eede94f48b9c4da74610ac108%26pid%3D100011%26prg%3D10629%26rk%3D5%26rkt%3D10%26sd%3D351129151726&tfrom=351129151726&tpos=unknow&ttype=price&talgo=origal
It is tiny! 2" by 2 3/8" Solidly built though. It has a few two-hole connection points on the board as seen in the photo, one is called "Key" What is that for? Thanks.
When I get to testing this I have been thinking I can use my two trickle float chargers as input to simulate a solar panel with the voltage inside the range of the gizmo.
Each charger is 2 amps and makes 14.2-13.4 volts , floating at 13.4 steady. So I think I could put them in series and get about 28 volts and 2 amps to feed the gizmo, then it should have about 4 amps at 14v output?
I will also try it on the 37 volt solar panel once I get its voltage down a bit (shading a cell or two ought to work) so it won't fry the gizmo.
(This was all just to explore the part the buck converter plays in an MPPT controller. I haven't thought of anything this gizmo could do that I can't do now with other equipment, but maybe something will occur)
  • 12thgenusa wrote:
    You'll only get 4 amps minus losses. Each unit puts out about 27 watts. 54/14 = 3.8.
    Power sources in series amps don't add.
    Thanks, yes I will correct the OP.
  • Oh yeah, that's right... you would need 4 power supplies, just as you need 4 batteries for series/parallel.
    But either way, your experiment would show how many amps are gained thru the bucking process.
    yes I said bucking, not... :)
  • You'll only get 4 amps minus losses. Each unit puts out about 27 watts. 54/14 = 3.8.
  • Thanks. I do have it in hand. Underneath, the two holes are not in the same solder, but they are in a busy area where each hole may be related to its own small collection of things, with those collections linked, no idea.
    If I can just ignore the Key part then I will :)
  • My guess is that printed circuit board is used for numerous converter applications and is not utiized in the configuration you are purchasing. There probably is a model where the converter can be activated via an ignition key (such as in a golf cart) but that model does not appear to be for that use. If you look at the bottom of the board when you receive it the two "key" holes are probably bridged together.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
