- Bob_ShawExplorerA #2 Phillips is fine as long as your not working on a Japanese or Korean car or cycle that the JIS standard. A Phillips wont fit tight and will strip out the head of the screw.
- Gene_GinnyExplorer
Campfire Time wrote:
In a telephone company central office we didn't have the option to turn off the power, you worked with a live bussbar all the time. Have you ever seen what a 1,000 amp 48 volt supply can do to a screwdriver? (yes, that is one thousand amp. some larger ones were four thousand amp.)
Suicide prevention? Maybe I'm missing something. I just turn the power off when messing with anything electrical. Easy peasy. - MEXICOWANDERERExplorerThe screws I'm talking about are Misery Inc. Without the right bit, connections cannot be tightened enough. Two are in the shopping basket.
- Bill_DianaExplorerHarbor Freight #2 Phillips Head screwdriver is my all time favorite, most functional tool. And for $1.79 you cannot go wrong. That's all I need.
- hersheyExplorerWiHa makes some of the finest small tools today. I particularly like the WiHa allen type screwdrivers. Even the smallest size allen, remains sharp and will not screw up (sorry, bad pun) the smallest allens.
- MEXICOWANDERERExplorerHonorable People's Liberation Army Heroic Dragon Factory 116 consume bed spring soup can and Suzuki fender, stamp out part, send to Camarillo, California on slow boat.
- SCVJeffExplorer
gbopp wrote:
Harbor Freight makes TOOLS?
Are you trying to say the quality of Wiha tools is better than Harbor Freight tools. :B. :B - MEXICOWANDERERExplorerTry working with those screws deeply sunk into a terminal block - using a phillips or straight blade screwdriver. Cursing, wailing, stripped screws, broken blocks. Enough to consider doing a two-and-a-half gainer out a fifth floor window...
- Campfire_TimeExplorerSuicide prevention? Maybe I'm missing something. I just turn the power off when messing with anything electrical. Easy peasy.
- MEXICOWANDERERExplorerRolls Royce versus Yugo, time.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
