fixpro256
Oct 31, 2019Explorer
Doughrainer, When you say "Per Dometic", what do you mean by that?
The original thermistor and the new Dometic thermistor that I purchased, both act the same.
I also purchased a pack of thermistors that are intended to solder into a circuit board. They are not the same, but similar. I soldered on some wires and surrounded in heatshrink. It works like it should. It turns the fan on high in freeze mode.
So the question is, is it the Dometic thermistors that are the problem or the circuit board? If there are only a few people with this problem, it isn't a big deal. But if thousands of us are having this problem, then Dometic should have their TS people just send a part as soon as a customer says they are having this problem. But so far, they are acting like this is an isolated and rare problem. They are telling me to call/pay a technician.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
