Reisender's avatar
Dec 31, 2020
Building a power pack. Need a battery recommendation. T
Hi folks. I’m building a portable power pack. I’m looking for recommendations on a 40 to 60 amp hour battery. Something around the size of a group 24 ish sized battery or smaller. Part of the project is a 500 watt sine wave inverter. It will be moved from time to time so I would consider a Lithium (probably lifepo4) although an AGM would probably be fine. (Good exercise). Indoor use. Probably using a group 27 or 31 box as the project box. I would appreciate any suggestions on the battery. I did this years ago with a blue top battery and it’s still working well. But things have changed a lot in the battery world, especially with lithium and AGM and I know there are people here who are more current than I am.
I should probably get suggestions on a small charger as well in the case of lithium. In the last one I built I used a small 3.5 amp NOCO charger and mounted it right in the box. Any suggestions are welcome on any newer chargers. I’m open to anything.
Thanks all. Happy New Year.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
