DrewE
Apr 13, 2016Explorer III
Commonly in shower enclosures in RVs (and probably in other applications) the wall panels extend down over and in front of the lip of the base a few inches, with no sealant between the two. That allows for some movement of them relative to each other. Caulked joints don't last well when there's much movement at all (at least with traditional caulking materials like silicone), and any slight twisting of the vehicle chassis will cause movement between the base and the walls. There's probably less slop in a van chassis than a typical class C or A motorhome chassis, but I suspect still more than in a house.
There's no real need to put plastic on the ceiling IMHO. It's not harmful, just unnecessary. If water is dripping onto your ceiling, you have bigger issues than a wet ceiling.
Be aware that once silicone is cured essentially nothing will stick to it. This includes more silicone. Resealing a silicone joint requires removing every bit of existing silicone and thoroughly cleaning the area and is a major pain. Other sealants may be more suitable; I've generally had good success with OSI Quad, though I have not tried it in any bathroom or other interior applications.
Depending on your height and the interior space, you may want to consider a ceiling-mounted track for the curtain rather than a rod for greater headroom when entering and exiting the bathroom. Having the exhaust fan not be in the shower compartment itself is actually not a bad thing, in my opinion, as turning on such a fan in a tight shower stall tends to cause the curtain to blow in and stick to one's body. Having it tend to waft outwards is pleasanter.
I assume you've probably thought of this, but just in case you have not: put in a towel bar somewhere. I like to believe that a towel is less likely to slip off of a square one (such as I've installed in my motorhome) than a round one, but I'm not sure that it actually makes any difference.
Edit: if you leave the shower compartment door open while showering (and use just the curtain to keep water where it belongs), the inside of the bathroom compartment door would be a decent place to hang a towel. If you have it some other place in the van to dry, you could just toss it on your kitchen counter or something before stepping in the shower and reach it when you need to dry off.
