2oldman
May 18, 2013Explorer II
jcpainter wrote:This makes no sense. As....
I've been told that Camping World used to sell the Zantrex (Xantrex) inverter and that it worked fine with the Onan generator.
smkettner wrote:That's pretty much layman's language as to what's wrong.
Generator and inverter are neither compatible or incompatible. They are separate and should have been installed with separate transfer switches so that they do not connect at the same time..
That's not the most expensive IC I've ever seen, and it appears to only have outlets, not hard wire, which is kinda weird for that type of unit.
OP- You may want to bore us with the details about what doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
