time2roll
May 18, 2013Nomad
Yes it is sine wave. Although the wave form might get a bit distorted under load. This may reduce maximum charging power when charging batteries but should not be an issue generally.
All generators that use a rotating armature are sine wave. The sine wave is a natural result during power generation.
The only way to have MSW would be an inverter generator that uses a MSW inverter to create the wave form. Kipor is the only one that I know that has such a model.
What is the real issue again?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
