2oldman
May 18, 2013Explorer II
jcpainter wrote:What happens if shore is on?
HOWEVER, if the shore power is turned off and the generator is turned on (to power air, microwave, etc.), nothing in the new circuit box will run.
Since with most IC's you cannot charge and invert at the same time, it would appear the new circuits are only powered from the inverter. This is why I installed mine "whole house" so these issues do not appear. The only "incompatibility" is the way it's installed.
FYI - my Prosine IC was pretty picky about 'shore' power including generators and wouldn't pass AC it didn't like.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
