time2roll
May 18, 2013Nomad
jcpainter wrote:
HOWEVER, if the shore power is turned off and the generator is turned on (to power air, microwave, etc.), nothing in the new circuit box will run.
Faulty, miswired or nonexistent transfer switch between the main panel and sub panel.
Inverter is irrelevant.
Or maybe CW expected you to run these sub panel items on inverter full time (transfer switch not used)
Apparently it has an internal transfer switch.
I assume it is hard wired. Is there a 120v input and output power cable attached?
What does the display say?
Any error codes?
Inverter Manual
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
