mena661
Jun 01, 2013Explorer
jcpainter wrote:You mean 5500. Yes, there are a multitude of these generators powering a multitude of inverters, PSW or MSW. Nearly every Class A motorhome has that generator (or larger) in combination with various inverters. CW simply did not perform a proper installation IMO.
Back to the question . . .
Is anyone on this forum running the Onan Marquis Gold 5400 generator with a pure sine wave inverter?
Thank you . . .
EDIT: Reading major's post...cheap, weird inverter.
People often add to a conversation without having background with the specific components a person is having the problem with - and make a lot of assumptions.That's because, in this case, there SSSSOOOOOOOOOOOOOO many inverters that work just fine with the Onan genny's (do you read any inverter/generator threads on this forum). It's most certainly acceptable IMO to troubleshoot from this particular bit of knowledge.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
