Chris_Bryant
Jun 02, 2013Explorer II
jcpainter wrote:
They said that their inverters needed perfect input from the generator in order for them to produce proper Pure Sine Wave output.
They do not know what they are talking about- the unit doesn't take pure sine wave power to produce pure sine wave power- it takes DC power. It uses input power to produce DC. Being a sine wave inverter has zero to do with it.
On the Xantrex- and I am certain the Magnum- you can set parameters for input power- both voltage and frequency. If the input power meets these parameters, it will pass it through while charging the batteries. If the power is bad, it will either not pass any power, or simply provide power from the inverter.
Anyway- glad they took care of it.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
