2oldman
Jun 02, 2013Explorer II
Too bad you can't do this yourself. From where I'm sitting you're just getting a load of BS.
The kind of piece-meal installation you're describing is a waste.. esp with a big IC like yours. Of course you can run your microwave with it, and you should. But - and this is another problem - only 2 batteries isn't going to cut it. Your IC manual should talk about having a minimum of 4. You've got some serious power there, but you have to feed it.
I'd install it "whole house"..after shore/generator and before the main panel. Then everything runs, and you just leave off the WH and air.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
