mapguy
Sep 25, 2013Explorer
mchero wrote:
NICE Job!
Agree -very tidy job.
Other posters have advised you to use silicone based products for places not on the roof. DON"T DO THIS! It is nearly impossible to do spot touch up sealing with silicone products. Plus urethane based products work better with metal and gel-coat or FRP panels.....
On your delam -it can be fixed in methods that don't require the walls be stripped and removed. First and foremost -the water intrusion must be stopped before any re-bonding/re-laminating is done. Second, the best repairs require the substrate to be reasonable sound and dry. Some of the epoxy systems will work with moist areas but make sure the leak is gone!
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
