ksg5000
Sep 26, 2013Explorer II
When I had minor delam issue I drilled a few small holes and injected a epoxy made by West Marine - delam is common in boats and this was the method proposed by the boat expert I talked to. Once the epoxy is injected you need to press the RV skin tight against the rig and let set for a day or two - your rig has smooth skin so a piece of plywood held in place by 2x4 wedged against wall might work. Worth a thought. The tiny holes where the epoxy was injected can be cosmetically fixed with finger nail polish.
