Rmack1's avatar
Rmack1
bulge in potable water tank
On my last trip, I looked under the trailer to determine the exact amount of water left in my translucent water tank. The level could be seen.
I happened to be looking on the side (port) that had the system feed and drain plug, and all looked well. However, on the other side of the tank, reaching all the way to the other side of my TT, I noticed a large area between the metal supports that was bulging down. It formed a depression inside the tank that extended a couple of inches or so lower than any other part of the tank. Obviously, water will get trapped here that will not drain from the drain plug if the unit is level.
What caused this? It seems obvious that the tank should have had more supports in that area. Has anyone else ran into something like this? Has anyone been able to do anything about it?
________________
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 24, 2025
