2oldman
Jun 03, 2019Explorer II
Ron Nielson wrote:No it doesn't, other than right there at the busbar. It tells me you have, at some point, drawn too much current for too long. My RV won't handle a/c and water heater at the same time.
All of my neutral wires are burned at the buss at the breaker box about 2". Does this tell you anything about where a loose neutral connection is likely to be? I have read that the burnt wires need to be cut back to good copper and the buss replaced. Is that because the burned wires and buss has a higher resistance than clean connections?
Yes, burned wires have higher resistance.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
