dougrainer
Jun 03, 2019Nomad
It is usually caused by the Main Neutral coming to the buss bar being loose. Hopefully, you have enough extra romex wiring behind the breaker box to pull fresh romex and cut off the burnt/hot wiring and install on a NEW Buss Bar. Do NOT use the original Neutral Buss bar. Overcurrent draw will not cause this to happen as long as the Neutral wires are secure and tight. Doug
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
